This unit requires a internal and external mode of isolation, a spur inside and a rotary switch for the controls outside, being that some of this equipment is outside I assumed that an RCD protected circuit is required, the manufacturer warns against a 30ma rcd as the unit may cause nuisance tripping.I cannot get back to the mains and the loading of the unit allows for me to remove a single socket that sits in the correct location and fit a RCD spur in it's place,is there such a beast as a RCD spur rated at 100ma
