Heat shrink - what do you use to supply the heat? | Page 2 | on ElectriciansForums
Discuss Heat shrink - what do you use to supply the heat? in the UK Electrical Forum area at ElectriciansForums.net
E54,
Do you really use a naked flame?
Not a criticism, it's just I was taught never to use a naked flame always some indirect form of heat!
On the heavy stuff, ...Always!! Flame is adjusted to suit the type of heat shrink in use!! You'd need a very powerful heat gun to shrink some of the heavy duty heat shrinks, and you'd be there all day doing the job too.
You can control the rate and speed of the shrinking far better with a blow torch too. Like most things in this game, there is always a knack/technique to be learned, and this would be one of them. A slightly different technique would be used on MV/HV termination/jointing shrinkable kits...
Thanks all - interesting contributions. As you might imagine, the question arose during a good practice "discussion". Mini gas torch on standard h/s is my technique.
Regards.
E54,
Lol, I also use a Sintra type mini blowtorch on site but obviously avoid burning or carbonising the plastic. It's always occurred to me it might not be good practice but I've never had any failures so it's something I've never really looked into. In the workshop we have small and large heat guns for heatshrink we use when building panels but on site it's usually not so easy to get power and it's only occasional pieces of heatshrink so the mini blowtorch is far more convenient.
Blow torch does sound a bit harsh for shrinking heat shrink, how about the term ''gas gun'' ?? lol!! Either way there is no better method of controlled shrinking of heavy duty heat shrink, be it for LV or MV/HV...
By the way, this is the variable setting heat gun that i have, and that is generally used by the electrical contractors on the projects that i have been involved on. It's a Leister unit, and no i didn't buy it, too bloody expensive ...lets just say it was a used gift from the contractor!! lol!! Mine has the optional flat air nozzle. As powerful as this heat gun is on it's highest setting, it's no match for a standard gas gun on heavy duty heat shrink...
Strangely enough, it was the same unit that the swimming pool liner guys used to weld the joints on my pool liner in Cyprus.
[ElectriciansForums.net] Heat shrink - what do you use to supply the heat?
Reply to Heat shrink - what do you use to supply the heat? in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
The repair kit is actually sold by WAGO for that specific purpose (in the wall repair). I had wondered myself about shrinking individually first...
