Heat Shrink | on ElectriciansForums
Discuss Heat Shrink in the Australia area at ElectriciansForums.net
W
wallyanker
Hi guys and gals.
I need to move a light switch and reading through some of your previous posts about extending cables, crimping and heat shrinking the joints sounds the best way to go.
How much heat do you have to apply, are we talking hair dryer temperatures or will I have to go out and buy a heat gun?
Heat gun m8, the hair dryer won't touch it. My m8 uses one of those gas powered soldering irons brilliant little tool, alternatively you could just use a normal electric soldering iron with a heat deflector attachment.
Reply to Heat Shrink in the Australia area at ElectriciansForums.net
I would add though that a typical good TT rod of 100 ohms only needs 3V to have 30mA flowing and so trip an RCD, you might find that sort of N-E...
Try disconnecting the "central heating off" wire from terminal 2 and insulate it (eg Wago connector or choc block or similar) and tuck it out of...
2 3
4K
