HEAT TRACE - What should be used as means of disconnect? | on ElectriciansForums
Discuss HEAT TRACE - What should be used as means of disconnect? in the UK Electrical Forum area at ElectriciansForums.net
afghanistan
Currently overseas and inside a small pumphouse heat trace is required.
Wondering if I need double pole RCD protection for it?
Thanks in advance.
All the trace heating supply circuits I’ve came across in existing buildings have not had RCD protection.
Reply to HEAT TRACE - What should be used as means of disconnect? in the UK Electrical Forum area at ElectriciansForums.net
I've seen a few posts here which tend to suggest that wiring in a motorhome (or caravan) wouldn't be subject to normal inspection rules, but even...
There is no reason for an item of fixed equipment to be on its own dedicated circuit just because it is fixed equipment. There may be other...
loz2754
L
