heated bathroom mirror | on ElectriciansForums
Discuss heated bathroom mirror in the Australia area at ElectriciansForums.net
brs73
up north london
hi there
i've been asked by a client if its possible to fit something to heat his bathroom mirror.
the problem being that the existing mirror cannot be removed.
i've looked around on the net and all i can find is pads etc to fit on the back
any ideas??
cheers
I have these in my bathrooms. You need to fit the heat mat, made by Devi, to the wall before the mirror is fitted. Then you simply stick the mirror over the mat with mirror adhesive. It is very similar to a ufh mat.
A word of warning to anybody fitting these. DO NOT USE NORMAL SILICONE SEALANT to stick the mirror, it will kill the mirror, only use mirror adhesive. I get the adhesive from a local glazing supplier in Darlington.
They are very effective, no more wiping the mirror whilst shaving!
Take a look at the website
Deviclear Mist-Free Mirrors
Reply to heated bathroom mirror in the Australia area at ElectriciansForums.net
Thanks all. Sounds like I hadn’t completely missed the point on what Part P needs at least. I’m not so much worried about a knock on the door as...
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
