Heater elements | on ElectriciansForums
Discuss Heater elements in the UK Electrical Forum area at ElectriciansForums.net
loplug
Cornwall
last week i went to a leisure center to check some heater elements in the spa pumps so i checked the insulation resistance and measured the resistance of the elements and listed these results for the customer. today i got an email forwarded from the customer saying that they need the "element draw figures across the 3phase V/U/M" what does that mean? it is not a term that i am familiar with.
It's not a very good phrase but it's probably referring to the current they draw when they're running.
If you know the resistance and you know the supply voltage and you know the way they're configured then you can work out the load currents on each phase with a pen and paper.
I'm not sure what 'V/U/M' is, is it a multistage heater perhaps?
(note; A pen and paper is something that was fashionable before iphones and apps were invented. ;))
Reply to Heater elements in the UK Electrical Forum area at ElectriciansForums.net
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
