P
Paul Downham
Hi all,
quick question to anyone out there, I am in the process of fitting x3 heaters in a static caravan. Each heater is 2000w. I calculate a 2.5mm ring being sufficient for these with a 13A fused spur for each. Do you agree? I am taking into consideration that in the deepest cold winter these x3 heates will all be on full blast, plus washing machine, tv......etc.
Also, how would you incorporate the spur within the ring (if using the existing ring)? Do break into the ring and incorporate the ring into the supply side of the spur?
If there is enough room in the FB I am thinking of running a ring just for the heaters with it's own 32A breaker.
Paul
Paul
