N
Noob2013
Hi there,
Just after a bit of advice for a family members central hesting system.
They have an old style Centroller 3000 controller which controls the central heating and hot water.
The system is a back boiler (not a combi) with a hot water tank, pump and a honeywell 3 port valve.
Central heating works fine when it's selected on the controller, but when you select to have the hot water on aswell, it stops the central heating and allows hot water.
So the both work fine independently but not at the same time which they used to. They say you can hear the controller click off when the other option is selected. I'm having a look today so after a bit of heads up advice.
The pump is only a few years old and is running, though it feels pretty hot.
Does it sound like the 3 port valve is faulty ( I know you can slide it to manual to get over it) or does it sound like the controller is playing up?
If it's the controller, is there any new style direct replacements for the Smiths Industries Centroller 3000?
I'm guessing it doesn't sound like an air lock issue either.
Any help would be appreciated.
