Heating controls | on ElectriciansForums
Discuss Heating controls in the Central Heating Systems area at ElectriciansForums.net
Market Harborough
Hi,
can anyone advise...
i would like to ideally use Honeywell.
i want the stats and programmer to be wireless.
it needs a frost stat
it also needs two stats and a programmer
and it needs three channels / zones
any ideas on how to achieve this?
I did one of those Honeywell courses but it's one of those things that unless you do it regularly it doesn't sink in.
its for hot water, and two different heating zones.
i don't quite know if it's possible to do it wirelessly
Wireless thermostats are common and come in programmable and normal varieties.
Wireless programmers I'm less familiar with, but you might find one somewhere (I've never yet found a need for one)
The frost stat will be wired and I'd recommend putting a pipe stat on the return pipe close to the boiler in series with it (presumable the boiler is what is being frost protected?) this would be wired to open the DHW valve if an open vented cylinder but must not if it is an unvented cylinder.
2 heating zones can be (normally would be) connected to the same channel on the programmer unless the customer specifically wants them timed seperately.
Drayton MiTime RF pack 5 but the programmer has to be hard wired as it's the receiver for both room thermostats and the cylinder thermostat and obviously it's what switches the valves.
https://www.plumbnation.co.uk/site/...KcUJ1RlytVn-EwGZCSCzKz7SAfQrM1GxjERoCdCPw_wcB
So you'll probably want a seperate single channel programmer in the granny flat to control that zone then?
Plus you'll want to think about making the stat in the granny flat easy to operate. I've lost count of the number of houses I've been to where customers (usually the older generation) who have wanted fancy roomstats changed for simple dial types.
Can't say I'm aware of any wireless programmers but your best bet would be to use 2 wireless programmable room stats for the 2 heating zones and a single channel programmer for the hot water
hi
have done a RF hot water cylinder on system change due to the fact that the old cylinder did not have a stat & heating engineer wanted a unit. we did a battery unit with probe that contacted the unit back at the mains. had a over button on the mains unit so even if they lost battery they could then push button for manual control. was a while ago, then heating was prog RF stat.
hope it helps
Reply to Heating controls in the Central Heating Systems area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
Programmable digital cylinder stat I bought one of these: and I am using it to control the temperature of my hot tub, and it works great. Does...
siricosm
