heating controls | on ElectriciansForums
Discuss heating controls in the Australia area at ElectriciansForums.net
M
mogga
iv got contactors,timers and stats to fit to panel heater circuits today and tomorrow BUT unknown to guy who surveyed( had a look and counterd heaters) there is a system inplace already its dimplex panelheaters with controler modules which are removable and a wall mounted timer stat which appears to be wireless Does anyone know much about this and could it be convertedd to simple contactor on each circuit?
The wireless stat just sends a signal to a receiver. The receiver then has relay contacts that change state and usually control the on/ off to whatever you require. I've go the same system for my central heating. I have already had to replace a receiver as the contacts were not changing over.
Why are they fitting new stuff? You say that the survey didn't pick up that there were controls in place. But did the old system stop working hence the survey?
Reply to heating controls in the Australia area at ElectriciansForums.net
There's a church in a town near me that has solved the heating problem for most days by building what is essentially a large timber and glass...
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
