heating for shop | on ElectriciansForums
Discuss heating for shop in the Australia area at ElectriciansForums.net
Y
yelp
can anyone tell me the best way to heat a shop with an area of 450sq ft?
with hot air???
bonfire in middle??
maybe with a climate system controlled via a controller so you can set A/C or Heat to blow from ducting?
thank you durhamsparky...witty comments appreciated :) i meant to say the most cost effective/practical way! i think i'm gonna go with either a wall mounted fan heater or one of those over door air curtains
I used to work for a very popular greetings card company they used over door heaters at the front of the shop middle and rear , they were made by thermoscreen , the other makes used were claudgen and dimplex AC30 and 45 , but they are not cheap to run as you can imagin but could be controlled by a room stat and contactors
I used to work for a popular mobile phone shop which used to sell carphones back in the day and is in fact still called 'The Carphone Warehouse'; heating in the smaller stores was provided by an air curtain over the door and an a/c cassette in the ceiling grid which had heating capability; in the larger stores or in shopping centres the air curtain was omitted and/or and extra cassette added.
The backroom areas had central heating (radiators).
Reply to heating for shop in the Australia area at ElectriciansForums.net
Yes, gravity mode is not used much now, (thank goodness) it was for old systems where the hot water from the boiler convection circulates to the...
I accept no liability for this - suggest you do the sums, but this is what I got: volume of that aluminium is .002 cubic metres (width x length x...
