Heating installs | on ElectriciansForums
Discuss Heating installs in the Australia area at ElectriciansForums.net
T
timo
Not done one yet but was wondering about filling in paperwork for heating installs.
Cables to pumps, valves, stats etc. Would each have its own readings recored or such??
Hows everyone else doing them ?
Cheers All
We just R1R2 to the isolator,insulation test the whole lot.... L-e/n-e...as long as you dont go L-n you are not going to fry anything, Zs to the isolator.....always have done....NIC inspector has never picked it up so I guess they are satisfied with that.
Might be wrong though...maybe we should be testing all the wiring.Even so you would only record the highest R1R2 and Zs as all the controls are part of the same circuit.
Very much agree with all that..
Test up to the FCU and certify that.
I have my C&G heating controls qualification, but i dont know enough about motorised valves, thermostats, boilers, etc etc to be carrying out full tests on them.. I can fit them, and i can fault find to tell if theyre working or not.. but after that its back to manufacturer or specialist guys.. !
Reply to Heating installs in the Australia area at ElectriciansForums.net
The 4 pumps are :- 1. boiler to cylinder 2. C/H and UFH circulating pump 3. UFH dedicated pump after manifold 4. DHW circulating pump. (this just...
There's a church in a town near me that has solved the heating problem for most days by building what is essentially a large timber and glass...
