Heating on a PIR | on ElectriciansForums
Discuss Heating on a PIR in the Australia area at ElectriciansForums.net
B
brizospark
Just received the drawings for the new job I am going on to. A new build with a lot of small rooms
It seems that they want the heating controlled via a PIR and contactor box mounted in rooms
Has anyone installed a system like this and can anyone describe in further detail how this system works
Thanks in advance
seems the pir is replacing/controlling the stat,tho imagine it would have to go thru a timer relay to give enough heat,never seen that set up before,it could work tho
Reply to Heating on a PIR in the Australia area at ElectriciansForums.net
This controller might do the job if you have single colour strip. You'll still need a power supply prior to this! Lots of additional features you...
glad it was such a simple fix..... And good job the previous owners didnt take it with them
