Looking at a heating system tonight, grasslin 24 hr time clock and 3 Zone valves ,down stairs heating , upstairs heating and hot water.
Upstairs heating and hot water not firing boiler. But valves are lit up. So when I turn upstairs heating stat down the valve light goes out but you don't hear the quizzing of the valve closing like it should , can the valves jam open and stop sending power to boiler? If it was jammed open , would the water not flow to heat from downstairs loop.?? Is their a way of fixing jammed valves or isit bin thx trev.i
