Heatstinkg | on ElectriciansForums
Discuss Heatstinkg in the Australia area at ElectriciansForums.net
What are you heatsinking would suggest you use a thermal transfer paste between the heatsink and the equipment can't make any other suggestions as your question is very vague
Heat stink lol,
You just crimp it the slide the heatshrink over it and use some form of hot air blower to heat shrink the heat shrink tightly over the crimp.
Here is a You tube vid not the best example but its pretty easy to do anyway, bearing in mind you will be crimping as well, put the heat shrink on to one side before crimping.
[ame]http://www.youtube.com/watch?v=4Z3f1-KJbd4[/ame]
Oh we can't embed here so just click to blue link mate.
Reply to Heatstinkg in the Australia area at ElectriciansForums.net
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
No joy unfortunately. A guy from TasNetworks came out and took a look. The line is currently too low, and they would not be able to get it to...
