Heatstrip THE3200r Trips Switch | on ElectriciansForums
Discuss Heatstrip THE3200r Trips Switch in the DIY Electrical Advice area at ElectriciansForums.net
Seaforth
Our sparky has just installed 2 x Heatstrip THE 3200 strip heaters (13A Max Each) which keep tripping the switches in the power board.
We have checked the cabling (20A Max Each) as well as the Power board (50A) to ensure capacity.
Reading the manual the guide recommends hardwiring the heaters as opposed to a plug and socket.
Could the fact that they have been wired via a plug and socket be causing them to trip, or is this a red herring?
Thanks in advance
what is tripping (MCB/RCD)? and what rating?photo would help.
You’ll have to excuse my ignorance but MCB
  • [ElectriciansForums.net] Heatstrip THE3200r Trips Switch
can't tellfrom photo. what do they have on the front of the breakers. B16?
Reply to Heatstrip THE3200r Trips Switch in the DIY Electrical Advice area at ElectriciansForums.net
Since my last post I have used the oven several times and it is still working ! On reading the 'regulatory' position I will ask an electrician to...
My wife’s Evoque gets about 32 miles on a full charge and I get about 28 miles on my F-Pace. I don’t know how long a full charge takes but I...
