Heavy duty Timer Light Switch | on ElectriciansForums
Discuss Heavy duty Timer Light Switch in the Australia area at ElectriciansForums.net
J
Johnnymag
Hi,
I'm looking for a timer to replace a standard light switch which has been installed to control a pond pump rated at 700 watts (max) but all I can find are units rated at up to 400 watts.
Anybody come accross anything like this or have any suggestions?
Thanks a lot.
Johnnymag
I would put a mechanical timer switch like a greenbrook T100-c timer or something simelar. easy to use and they normally have a rating of 3-3.5kw depending on the brand.
Hope this is of some use or have i missed the point entirley?
Reply to Heavy duty Timer Light Switch in the Australia area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
