G
GatwickGaz
Hi there, I am new to this site. It looks like there is a lot of useful info here. I am an electrical engineer contracting to a DNO (11kV and 33kV) and do not have an in depth knowledge of electrical regs.
Here is my problem which I hope some kind person can answer...
We have moved into a new house. All the en-suite and bathroom fan isolation switches (on the wall outside the room) have been mounted so high that they cannot be reached without something to stand on. I have raised this as unacceptable with the developer. He says they are for isolation only, i.e. not for regular on/off use, although I think he has somewhat shot himself in the foot, as there is the same set-up in the utility room presumably to extract if a tumble drier cannot vent directly outside. This isolation switch is also out of reach.
My argument is the common one of fan noise which I saw posted on another thread. At night if just using the en-suite loo, no-one really wants a fan running on and keeping them awake. Also in this day or energy saving when people are starting to turn off applianes from standby, surely I should have the option to use the fan or not. No on needs a fan when cleaning their teeth!
Now after the pre-amble, here are the questions
Gary
- Are there minumum and/or maximum height for the isolation switches?
- Are there any Regs (presumably Building Regs??) that state that the fans should be on whenever the light is on in the bathroom/en-suite?
Gary
