hello can someone tell me the meaning of LAP (specifically) dimmer ? is it different than normal dimmer switch? | on ElectriciansForums
Discuss hello can someone tell me the meaning of LAP (specifically) dimmer ? is it different than normal dimmer switch? in the UK Electrical Forum area at ElectriciansForums.net
kujah1
uk
I would normally try to get the VARILIGHT ones, they also work tolerably well with most dimmable LED lights.
(Generally to get good dimming for LED stuff you need to have the fancy 0-10V controlled ones, not had the pleasure of using that for myself though).
Reply to hello can someone tell me the meaning of LAP (specifically) dimmer ? is it different than normal dimmer switch? in the UK Electrical Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
