HELP! 2 way 2G dimmer with downlight! | on ElectriciansForums
Discuss HELP! 2 way 2G dimmer with downlight! in the UK Electrical Forum area at ElectriciansForums.net
salmanhamid
Hi All
Apologies if it is a basic question and has been discussed here before.
We are putting new spot lights in our bedroom and I am in the middle of buying all the stuff we need, we are putting 9 lights for the bedroom, GU10 240V with 50W lamps, outer 6 will work on 1 dimmer and inner 3 will work on one. My question is, is this dimmer suitable for what we are trying to do cause Im unable to find 2G 2W decorative dimmer in 400W all I can find is 250W one :(
Crabtree 2G 2W 250W Dimmer Black Nickel | Screwfix.com
Any help and suggestion highly appreciated.
Thanks in advance and help
We are planning to having 2 dimmers in the room one above the bed and one at the entrance thats why wanted 2 way, is that not possible?
Do we need to tell building council that we are having spot lights?
In a word no 6x50W = min 300W. You don't need it to be 2Way unless you are also incorporating a standard switch as well.
Something like this should do for the "outer 6": 1 Gang 2 Way 500w iQ Dimmer Switch
Don't forget this will need notifying to building control at your local council, that will add to your cost.
Possible, yes. Will you get the result you desire, I doubt it! Put the simple on/off switch at the entrance to the room and the dimmers by the bed.
You have two controls to consider one governing 6x50W = 300W and one governing 3x50W=150. So 1x400W and 1x250W should do for the dimmers and then a 2g2w switch at the room entrance. The real question is which side of the bed do you place the dimmers :)
Reply to HELP! 2 way 2G dimmer with downlight! in the UK Electrical Forum area at ElectriciansForums.net
