Right, here goes, i need something that i can use to convert a temperature signal into a voltage output, basically the boilers we use have a feature called back end protection, what it is it closes off the main flow and return to the cylinders until the boiler is up to temperature, then it actautes a 3 port valve to allow the heated water to flow into the cylinder, normally this is controlled by the boilers control system but in this instance its not, the temperature control is 0v analogue and the 3 port valve has forward and reverse, so what i need is an interface to control this, any ideas, i dont mind building one but i need a bit of guidance.
Anyone??
Rob
Anyone??
Rob
