Help choosing wire | on ElectriciansForums
Discuss Help choosing wire in the USA Electrical Forum area at ElectriciansForums.net
Sweetfarm
Rhode Island
Hi everyone. I’m hoping for a little advice. I am hiring a certified electrician to do this job for me but I’m looking to buy the wire today. I am trying to hook up an outlet for my 30 amp RV and 200 feet away from my house. I I’ve dug and 18 inch trench and plan on using PVC conduit. Here is the outlet that I have purchased. https://www.homedepot.com/p/Midwest-Electric-Products-70-Amp-Power-Outlet-Box-U041CP/202307106
I have a friend who has a couple of schools of this. Would this do the job?
https://www.homedepot.com/p/Southwire-500-ft-4-0-Black-Stranded-3E-AL-XHHW-Wire-11277115/202250399
volt drop will be your biggest consideration. honestly, I'd wait for your electrician before buyng cable. expensive mistake if you get it wrong. for a 30A load @ 240V 70mm cable might just cope. that converts to 2/0 if I have got it right.
Sweet farm welcome to the forum and 30amps requires # 10 wire and at 200 feet my advise to you is buy 8/3 with a ground romex for voltage drop which is approved for direct burial with no pipe and if you do run pipe it would require 1 inch pipe. You can buy the wire at Home Depot for $ 2.17 a foot. If you have an electrician he should know all this, if not he is not an electrician, he is just somebody that does electrical work. Did he say he was going to draw a permit for this job ?
Thanks for your reply. I do have an electrician. He’s not the person who has the wire. I can get the wire very inexpensively and was wondering if it would work. I can certainly look into other options but none of them will be as inexpensive. The 4 gauge aluminum is $.25 a foot.
# 4 aluminum will work but it will probably be to big to fit into the lugs and it will also require a bigger PVC conduit. With the aluminum you will still need 4 cuts for 240vac with 2 hot wires 1 neutral and 1 ground. I did the math on 800 feet of 4 single # 4 aluminum and it will cost you $ 200.00 just for the wire. Good luck
norcal he was talking about # 4 aluminum wire not 4/0
I was commenting on the link in the 1st post. The 4 AWG AL spoken about later will be a good choice & will able to use phase tape to mark the conductors, rather then buying green & white conductors since 6 AWG & smaller must be colored green, or white, by code rather then taping black conductors.
I always use copper and it’s not that much more money and it is not nearly half the size of aluminum and easier to work with and get your bending radius right. The only aluminum you will see in my panels when I build a service is the power company’s wire which is always aluminum
Copper is the conductor of choice, but properly installed aluminum alloy wiring is fine, and a good way to control costs, if it was so bad PoCo's would not be using aluminum alloy conductors almost exclusively, the PoCo's do use compression connectors for terminating AL, but proper torque is required by the NEC, and is the key to a proper installation, no matter what the conductor material is.
Reply to Help choosing wire in the USA Electrical Forum area at ElectriciansForums.net
Hi There How did you get on with your basement project?
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
