Help converting t8 flourescnet to LED | on ElectriciansForums
Discuss Help converting t8 flourescnet to LED in the Lighting Forum area at ElectriciansForums.net
USA
I"m having an issue with kitchen lights. I'm in an apartment unit that used a light fixture with 2 t8 flourescnet bulbs (with electronic intant start ballast). I want to replace them with led bulbs. I removed the ballast and direct wired the tombstones (shunted), and the lights arn't coming on.
Heres the bulb im trying to install
heres the bulbs currently in the fixture:
attached is the direct wire config: 2 Blue wires on hot (black) one red wire on neutral (white)
the tombstones, being shunted, and 1 blue wire coming from each Left tombstone, whereas the right side has a red wire coming from one tombstone, but a blue with black striped wire connecting the 2.
  • [ElectriciansForums.net] Help converting t8 flourescnet to LED
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to Help converting t8 flourescnet to LED in the Lighting Forum area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
