Help, Electrical items from Germany, will it work in UK??? | on ElectriciansForums
Discuss Help, Electrical items from Germany, will it work in UK??? in the Australia area at ElectriciansForums.net
J
jjjj
Hi,
Just a quick one. I am looking to buy sone electrical items from Germany and I just want to check they will work in UK. I know I'll have to change plug but is that my only concern. Germany is 220v and 50hz and Uk is 230v and 50hz. Item electrical information is as follows
Energy consumption: max. 28 W.
Power supply unit: 100-240 V / 50-60 Hz.
Am I right in saying that it will be ok??
Not great with electrics so any help will be greatly appreciated.
Yes, it should work fine if you put an appropriate plug on it. Same with stuff here in South Africa, we also have 220v and our electrical items work fine in the UK and vice versa..
I thought the reason we now have 230 volts (ha ha ha) was to harmonise with Europe, or some of it. Anyway as long as the supply requirements go up to 240 volts 50 hz you should be fine to use the kit in UK.
Reply to Help, Electrical items from Germany, will it work in UK??? in the Australia area at ElectriciansForums.net
On a small generator I wouldn't want to risk using diversity as they are not quite as forgiving as a mains supply and can very quickly fail when...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
