help for your 2391 | on ElectriciansForums
Discuss help for your 2391 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Stu spark
loook up chris kitcher on you tube a step by step guide for each test is available also very handy if you are a bit rusty. he also has a book published which is a great help. i just want to add i recieve no commission for this just thought it would help people out as it did me
In stage two one of the things you are checking for is inter connections between line and neutral in the ring at each point in the circuit when you do your figure of 8 which in a way is correct polarity
Upvote 0
I disagree with a few of his points, however as GStueyXR stated, his book is excellent.
Except for the picture on the front, which makes no sense to me :confused:
Upvote 0
Reply to help for your 2391 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
I believe that it is incorporated into the 5 days. But will double check. Thanks.
Best Electrical Courses I endeavour to create a "best electrical courses" thread for 2025 (so training courses that did well during 2024 are the...
Electrical Courses
