Help fuse wire | on ElectriciansForums
Discuss Help fuse wire in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
lister
Old main incomming fuse, pot with 100a fuse wire, what is it as far as a EIC is concerned?
bs??
bs??
BS88,did post something earlier,will try and find it and post it.
BS 3036 Rewireable Fuses
BS 1361 Cartridge Fuses (Consumer Unit Type)
BS 1363 Plug Top Fuses
BS 88 Cartridge Fuses (General purpose)
BS EN 60898 Miniature Circuit Breakers
BS 3871 Miniature Circuit Breaker (Old Style)
BS EN 60947 3 Main Isolators
BS EN 61008 Main RCDs
BS EN 61009 1 RCB0s
BS 7288 RCD Sockets
BS 1363 13A Plug Tops
Sorry Lenny,thought he was on about main incomer:eek:
3036 of course it is, doh
Thanks guys, long day, still trying to catch up on paperwork, brain gone:)
Were you on about the incomer or fuses in the board:confused:
Reply to Help fuse wire in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
