Help identifiying a cable please | Page 2 | on ElectriciansForums
Discuss Help identifiying a cable please in the UK Electrical Forum area at ElectriciansForums.net
Ross1
Im carrying out a PIR, there is a 3 core (what appears to be solid aluminium armoured) cable supplying one of the single phase DB`s. the solid cores are almost triangular in shape, colours of cores are RYB. The csa looks anywhere between 16mm and 25mm/sq.
Any ideas on cable type and so I can find out the ccc.
Aluminium wire armoured cable
Steel wire armour is only used on multicore versions of the cable. A multicore cable, as the name suggests, is one where there are a number of different cores. When cable has only one core, aluminium wire armour (AWA) is used instead of steel wire. This is because the aluminium is non-magnetic. A magnetic field is produced by the current in a single core cable. This would induce an electric current in the steel wire, which could cause overheating.
Everydays a school day for me jeez
[ElectriciansForums.net] Help identifiying a cable please
Reply to Help identifiying a cable please in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
