Help installing new dimmer | on ElectriciansForums
Discuss Help installing new dimmer in the Lighting Forum area at ElectriciansForums.net
Sam22
Manchester
Have installed a dimmer previously, but wiring in this one is confusing me. Have a feeling there’s additional wiring being used because there used to be 2 switches in this room for 1 light, but there’s only 1 switch now.
Photos attached of current wiring and new dimmer. After reading online, I’ve tried putting everything going from L1 to C, everything from L2 to L1 and everything from L3 to L2. But that’s not worked, the switch just turns the lights on/off, no dimming.
[ElectriciansForums.net] Help installing new dimmer
Help please!
Is the configuration your using switching the lights correctly with the dimmer? Might sound silly but not all LED lamps can be dimmed
Do I understand that you only want to use one switch?
If so, you only need to connect up wires from the 2-core and earth cable. You do not need the 3-core & earth cable at all.
Simply put the brown into C on the dimmer and the blue in L1.
As above - this is assuming that your LEDs are dimmerable and are compatable with the dimmer.
OP says there's only one switch now!... That infers that the 3 core is going to another switch position where there isn't a switch.
How is the other end of the 3 core terminated?
3 individual connectors?
All 3 joined together?
Just cut off?
It’s a matter of what you do with the earth connection. If the switchplate is metal then it must be earthed. Not necessary if it is plastic.
Reply to Help installing new dimmer in the Lighting Forum area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
