B
benh33
ive pat tested a drill that as passed but doesnt work how please
Discuss help , ive pat tested a drill that as passed but doesnt work how please in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Must disagree here, function test can only be done after passing the all other tests, consider the earth broken on a drill with a fault and you do the function test first, it could kill where as the broken earth would show and fail on the tester thus stopping you doing a dangerous function test.It's wise to function test first.
I hope it wasn't a big Hilti or the like, could be a costly mistake!
Fair point, but what do you in the situation with the belligerent customer who turns round and says it worked fine before you tested it?
You pre-empt any customer what the tester actually does and during the high voltage and high current test that it may cause any weak points in the electrics to fail during the tests but highlight the fact that it wont cause any issues if the item is electrically sound, explain part of the device failed during the testing as the tester tests the device beyond its normal working conditions, failure during this testing means the item wasn't safe to use. Never let the customer assume you've broken it in the first place, with IT equipment i cover my back with a cover note about the info on the hard-drive could in rare circumstances be corrupted and they need to back up any important data.Fair point, but what do you in the situation with the belligerent customer who turns round and says it worked fine before you tested it?
you have time to talk at £1 a item ?
Sorry to say but very poor advice!
Reply to help , ive pat tested a drill that as passed but doesnt work how please in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
