[HELP] LED strip with Sonoff switch | on ElectriciansForums
Discuss [HELP] LED strip with Sonoff switch in the DIY Electrical Advice area at ElectriciansForums.net
alanlamsg
Singapore
Hi all
Need advice on my current LED light setup with Sonoff switch. Can I check if the Sonoff switch should be connected as highlighted in the picture? TIA.
[ElectriciansForums.net] [HELP] LED strip with Sonoff switch
That Sonoff device is intended to switch mains 240V rather than low voltage DC that you have there on the black and red wires to the LED strip.
So I should connect to the blue and brown cable instead? Thanks.
Reply to [HELP] LED strip with Sonoff switch in the DIY Electrical Advice area at ElectriciansForums.net
Hey MDJ, the one you see at the right ( the kitchen switch) is a momentary switch, but again that hasn’t been touched
seen a couple of your posts now and IMO you are trying to save money by doing the design and install yourself even though you have no...
