A
arturas
Hi there, i have been trying to find an answer everywhere but i couldn't.. so that's my problem, there is a stop cock which is about 300mm from a floor level, and after stop cock is plastic pipe connected which goes straight to boiler. Now the gas is coper and has been earthed within 600mm after stopcock and goes to boiler as well. Now is it enough to do a cross bonding under the boiler on all boiler incoming and outgoing coper pipes?or should i get new 10mm earth cable to boiler and then do cross bonding?should i bond the metal part of the incoming water before stop cock?thank you.
