accord, sounds like you generate alot of paperwork, which is no bad thing. You and your customer know exactly where you are at the start. I'd be interested to know if you use any specialized software for all this? I myself use a combination of spreadsheets and word documents, but it can become very clunky.
No special software - it's all spread sheets and Word Docs refined over time, and made into relevant templates. It's about as automated as it can be, but it means I can put a full spec out in an hour or so.
I use different paperwork forms depending upon what's required - but the real pain is tracking it all once in play - numbering can be a pain.
I know it's all something that could be automated a whole lot further with an Access or SQL database - just haven't had time at all to play around.
If pricing is not your thing may a price/job calculator is the way forward, it needs all the specifics though to make it accurate....
Yeah, agreed - pricing can be the bane of any job. And there are so many hiddens initially, it's easier to get it wrong than right.
Best, easiest thing to do is to build a basic spread sheet, listing everything, and with your mark ups already put in - so you can see the job build up in front of you.
For us, We put in materials at list price, then a labour time per "item" - so it calculates if we have ten of an item, or one, or three.....and give a line total of unit price, and labour time.
Then we apply our mark up to the total materials price at the bottom.
Then we add a margin for fixings, and other misc items.
Our labour rate takes account of direct overheads, and is set accordingly. The sheet then adds in the total labour * the labour rate per hour.
Finally, we have the sales total - but our sheet also calculates GM and GP for us too - which is transferred into another sheet automatically, against which I monitor our quotes, and margins, etc....
We can also quote buy-ins as part of the sheet - ground works, specialist commissioning, project management - stuff we buy in complete, that we don't do ourselves as such. And finally it can calculate sales commission - which we pay on profit, not on invoice value (hard to get your head round at times).
It's not a pretty sheet, but as a build up sheet it does what we need it to.
Critical calculations for us are labour rate - overheads - we need to know how much profit we make on our labour (or not). In simple terms, if our overheads are say £25 per hour - we need a labour rate in excess of that, which is generally set at a level and left there - say for this discussion, £35.
Margins are then calculated on the elements of the price that are not cost of goods - or cost of job - e.g. mark up on materials, profit on labour, mark up on buy ins, proportion of misc (less an amount that will actually be spent for finxings, etc., and so on.
After all that, it tells us two things - how profitable the job is, and how much room we have to move, should it be necessary.
Once the job is done, we compare the finished costs to the quoted costs, on an ongoing basis to make sure we're maintaining margin, etc. That's done in another sheet. We also, obviously monitor the margins on successful quotes, failed quotes, and so on too - to spot if we've gone in too high on particular work, or too low, - patterns develop over time.
Alot of worksheets then. How do you file them all?
I have an estimating sheet that some would say is complicated, but it doesn't do what yours does. I have seen some good examples over the years, some people have given me theirs and I in turn have shared mine. I do believe I sent one to andekoch from this very forum, he sent it back to me heavily modified for his purposes. a lot of work went into that spreadsheet when I made it and ande must have put even more time into it. It would be nice to have one program that does everything.
Funny that you mention Access. I have a friend who is also an electrical contractor, he taught himself VB and went on to make a database that does literally everything an electrical contractor would want, even certification. It took him 3 years to build!!!
Everything electronic. Backed up, and backed up again. We print as little as possible, preferring to use email and PDF formats where possible, right down to invoicing, which customers, on the whole, are happy with - but then we don't do domestics, where it would probably be more of an issue.
It is a lot of worksheets, ultimately - but that's kind of down to the business each of us wants to run - for some, the numbers are all important (or have to be) and for others, it's enough to do a day's work, and generate enough income from that to keep the family fed (which is I guess, what we all do, in varying scales anyway).
There is a key piece of business advice I was given many years ago, by a guy who's no longer with us (he died in a plane crash sadly) - and which has remained one of the single best pieces of advice I've ever been given for any part of my life - and that is keep it simple. In real terms, as simple as you can, to achieve the desired result. Seems logical, but human nature seems to be to find the most complicated way we can of doing a thing.
Over complication, especially of the nuts and bolts of a business, is as much a contributor to its eventual downfall as not doing anything in the first place.
The simple translation of all that is, I suppose, to do what works in each case.
As for Access databases - one day :)
Help me pricing a job.
Business Related
Mad Spark,
egginyourface,
