F
fixit4u
Hi folks
not had much fault finding experience do am asking if anyone can give me some help/advice pls, i was asked to look at a lighting fault by s plumber who said the bathroom lights where he was working had a fault on them worked then didn't work, the lights switched on with the switch so i took s reading at the switch ( megger ) it was not RCD so tested fast test, it showed 78volts and kept saying trip, i tried this at other light switched in bedroom down stairs, all shown same although were different circuits, i tested at the switch as couldn't get a test to work at the fitting itself, the rest of the house circuit's tested ok although a little high ??
any help pls ??
any help pls ??
