G
golum
Hello members.
Just wondering if anyone can help me with some information on a dimmer switch please as I can’t seem to figure it out no matter what I try?
I have a 3 gang dimmer switch, 60 - 400W, 230V a.c.
Circuit 1 = 5 x 35W down lights. Each light is fed from 12 volt transformer.
Circuit 2 = 5 x 35W down lights. Each light is fed from 12 volt transformer.
Circuit 3 = 4 wall lights (dimmable) with 2 x 20W lamps on each patress and these are also fed via a 12V transformer that are concealed in the lights enclosure.
The problem I am having is circuit 3 (the wall lights) is perfect when on full load but when they are dimmed (even slightly) a loud buzzing comes off the transformers (not the switch) within the enclosure and the lights flicker. I thought this might have been as the minimum power was not met and thus tried putting all 3 circuits on one gang but this did not change anything. Circuit 1&2 = no problem, Circuit 3 = headache.
Is there something that I am overlooking or has anyone else had this problem?
Do the 12V transformers change the total load power?
Thanks in advance for any replies as I have now ran out of options?
