Help needed - overhead wiring | on ElectriciansForums
Discuss Help needed - overhead wiring in the Talk Electrician area at ElectriciansForums.net
T
tronic
Hi all,
I am new to all this forum stuff, so apologies if this is in the wrong place.
I am doing a rewire and need to get to an outbuilding. The easiest way is to use a cetenary wire (concrete everywhere). I am going to use arctic flex but notice the regs say that PVC must be protected in direct sunlight, how can I achieve this??
Aaron
Reply to Help needed - overhead wiring in the Talk Electrician area at ElectriciansForums.net
I guess the easiest way would be to run a supply from ignition /aux via a relay that drops the supply when the lights are on.
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
