help needed please :) heating new build | on ElectriciansForums
Discuss help needed please :) heating new build in the UK Electrical Forum area at ElectriciansForums.net
714gold714
Hello everybody
Sorry if wrong section been a while since i last posted.
Basically i would like opinions on heating systems. Its a new build annex with 2 rooms and a bathroom I'm running a supply from the house. I don't have much experience with electric heating systems i was wondering what you would choose they want heaters in each room would convector heaters be best and what supply will i run to them? the customer doesn't want an electric boiler just simple electric radiators. will it best to run a time clock or have each radiator seperate with built in timer?
any help appreciated thanks
i'd use the panel heaters with timers and thermostats. either a 2.5mm 20A radial for 2 heaters, or a 4.0mm RFC for 4/6 heaters.
Reply to help needed please :) heating new build in the UK Electrical Forum area at ElectriciansForums.net
Good luck with your project and I’m starting in 2 weeks to install the same thing as you.
Your kWh figures are giving you consumption averaged over each hour period, but don't give an indication of total instantaneous current. To try...
