M
malcolmwelsh
Hope you guys can help me - seems to be two different opinions and dont know which one is right.
I have run a new supply from a house out to a shed/bedroom in the garden. The supply (3 core 4 mm) originates in the fuseboard in the house - earthing system for the property is TNC_S. The feed is protected by an MCB and has a dedicated RCD just for the outside feed.
I have two guys telling me different things - first guy says you should not export the earth from the house on an TNC-S system to a shed because the DNo's (EDF) do not like it. He says I should put an earth rod in which looks after the shed only. Something to do with if fault develops in the street somewhere there is a small chance it could find its way into the shed. Shed has its own 17th board with RCD protecting ring circuits. Really dont understand the logic of this?
Second guy says run the earth from the house as normal straight into fuseboard.
Who is right?
Who is right?
