help needed ring main fault | on ElectriciansForums
Discuss help needed ring main fault in the Talk Electrician area at ElectriciansForums.net
714gold714
hello there your expertise please :D
Basically recieved a job from a client that rents out propertys the client has had the council complete a EICR and they have found x2 ring mains have the following faults:
circuit 1:no continuity lives (readings-RN=1.33)
circuit 2: no continuity neutral (readings-R1= 1.28)
the fuseboard also needs to be replaced but i have told the customer before we change the board for new 17th edition consumer unit we need to correct these faults i was just wondering what you would do?
1) try find fault hourly rate take all socket fronts off and inter connect cables at board and test each socket until find break
2) change mcb in 16a and turn into radials
or recommend rewire sockets please note he doesnt want to spend alot (useual story) as hes just renting the place out
PS insulation ressistance readings are fine
thanks very much
It may be something simple that you can find easily,if it was my job I would spend a couple of hours on point to point tracing and take it from there.If you go down the rewire route from the outset he may think you,re trying it on and take the work somewhere else.
thanks mate thats what i though, i know these faults can sometimes be a night mare to find especially if theres any jbs hidden.
thanks for advice
Landlords p*** me off, they never want to spend a lot, but they want to charge top rents to tenants. Point him in the direction of the "Landlords and Tenants act". He has a duty of care, not to mention a legal obligation, to provide his tenants with a safe and serviceable electrical installation amongst other things. And you fixing it and upgrading his CU will ensure he complies with this, it costs what it costs, he will soon recoup the costs in rent, and it will be a whole lot cheaper than any day out in court he may have if he gets it wrong.
Cheers..........Howard
very fast in writing replys today on this forum :D
thank you all for advice
Howard you are correct most landlords are very tight and always want the famous how much for cash jobs doing
The sad thing is theres so many people who would be willing to take this job on for peanuts and not a care in the world for peoples electrical safety. People just dont seem to like spending alot on electrics
I found one a few weeks back, broken RFCs IR readings terrible, faults all over the place, Ra of 1360 ohms and a CU that had seen far better days. A 3 storey house and the tenant had 2 kids toddling about. I told him he needed to rewire, when I gave him the price he nearly choked complaining that he didn't want to spend too much money because he was trying to sell the place so could I get the CU changed which I refused to do. Turns out he got someone to throw in a ÂŁ50 B&Q special for ÂŁ100.
I'd be very surprised if he got any paperwork, luckily I kept the EDN so my bottom is well covered
Reply to help needed ring main fault in the Talk Electrician area at ElectriciansForums.net
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
