Discuss help needed to bypass touch switch on led light in the DIY Electrical Advice area at ElectriciansForums.net
Thank you for your reply the switches are encased in the end section i will attatch a picture but taking it apart doesnt help with the view there is a singular wire going to 2 switches the white on the left is the only one i need to work the second goes to a blue row of Leds which are not important.Welcome to the forum mate.
Can you take a pic of the wires going to the existing switch.
This was my first call, the part number returns no results as its a chinese ebay special.Make/model? Have you tried the manufacturers website for a board schematic?
4014SMD if that helps thank you for your reply.Just replace the whole unit for a suitable driver.
Do you know what type of leds they are?
I actually considered that haha! Thanks for the help!Probably get shot for this but email someone like bigclivedotcom, he's always taking Chinese specials apart, might be able to help you.
multiple strips but the 4 i want are wired to the one switch it is 15v 1.2amps.Are they in a strip?
Do you know the voltage or current rating?
Reply to help needed to bypass touch switch on led light in the DIY Electrical Advice area at ElectriciansForums.net
