J
JonnyHibbert
(I did post this in the central heating section too, but i thought it might be seen more here...sorry if that's not allowed)
This was supposed to be simple, but I'm struggling to wire up Netatmo wireless relay to the boiler and the Netatmo forums are a ghost town.
Current setup is a wired thermostat onthe wall, that I want to disconnect entirely and replace with the wireless netatmo thermostat.
In the first image below is the default wiring before i touched anything.
The second image is the default with the red and black removed. I connected the netatmo relay wires brown and blue to A and B (marked myself in paint) which I believe is for power, and the two other wires into C and D, which I think is the thermostat controlls.
The relay lights up but the boiler does not ignite, either through hot water turning on or through pressing the relay button.
This is possibly being caused by built in control panel on the boiler?
The wiring and instructions for my boiler are found here
http://idealboilers.com/installer/wp-content/uploads/sites/2/2013/08/mini_is321.pdf
Can anyone spot what I might have done wrong?
