I have a Square D 70 amp sub panel in the basement with no ground wire from the main panel. The HVAC contractors hooked up to 20 amp single pole Circuit breakers with putting the ground wires on the neutral bus do I need a separate ground bar in the case. Also how do I fix this can I ground to a water main line that’s grounded
