help on a part p question | on ElectriciansForums
Discuss help on a part p question in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
M
matt12321
came across this question today and was unsure
under the building regulations 2000, which projects are exempt from control?
a - the extension of a building by the addition at ground level of carport open on at least two sides
b - the provision or extension of a controlled service or fitting in or in connection with a building
c - work involving the underpinning of a building
d - the insertion of insulating material into the cavity wall of a building
Car port is exempt as this does not involve altering or changing the structure of the building IMO.
Hope that helps
Chris
thanks chriis
ive got a couple more if u don't mind answering them for me?
the installation of a ring final circuit is classed as a licensed fitting, building work or a defined service?
which one is notifiable under part p?
a connection of an electric gate to an existing circuit
or
the installation of pre assembled CE marked 12v down lighters in a bedroom.
Upvote 0
The second one is the electric gate, not too sure on the first tbh, think it may be building work, maybe someone can clarify this for you.
Cheers
Upvote 0
The Domestic Installer (part p) exam should be closed book, if they do let you take summit in try the electricians guice to the building regulations, all the answers you'll need will be in there.
Cheers
Matt
Forget tha above, didnt read yr reply properly!!
Upvote 0
Cheers
Matt
thats what im unsure about as the other part p exams ive had were open book, where we were allowed our regs and on site guide only.
thanks for the advice on the elec guide to the building regs tho
Upvote 0
If I remember correctly the part P or EAL VRQ is 20 questions closed book exam so nothing brought in with you. The 17th ed exam or 2382 is open book so you can have your OSG etc with you.
Chris
Upvote 0
When I did the 17th exam the ONLY book we were allowed to take in was the BRB, OSG wasn't allowed. Also with the EAL it was totally closed book, 20 questions, I think 40 minutes if I remember correctly.
Upvote 0
Chris
oh well, just have to revise a little more than usual and use a bit of common sense. yeh ive passed my 2392 and regs, all ive got left is the 2330 and this final part p exam.
Upvote 0
Matt for the part P exam concentrate on chaps 1 5 and 10 of building regs and know what each part of the building regs are ie part a part b part c etc.
That will get you a pass good luck
Chris
Upvote 0
Reply to help on a part p question in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Amazing, very informative and brilliant system.
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
Electrical Courses
