M
Morgan keith
I'm installing an aluminium framed groundmount PV system with an SMA 17000TL inverter and wondering about the array frame earthing. The posts are rammed about 1m into the ground. Do I need to install an earth spike for each array. The Array is around 120m from the main dist panel and incomer point so have a 50mm 4 core SWA cable for the AC side. Do I need to install a seperate Earth spike for external DB installed at array or is SWA earthing sufficient?
Many thanks
Many thanks
