Help on Earthing of structrual steel?? | on ElectriciansForums
Discuss Help on Earthing of structrual steel?? in the Australia area at ElectriciansForums.net
R
raymonddaly
Hi All,
I'm currently doing some work on a warehouse. I have noticed that there is NO Main Earth to the Structrual steel. I am going to install an Earth but my question is where's the best place to bond it to and does every Steel upright require a Cross Bond???
Thank You.
Hi All,
I'm currently doing some work on a warehouse. I have noticed that there is Main Earth to the Structrual steel. I am going to install an Earth but my question is where's the best place to bond it to and does every Steel upright require a Cross Bond???
Thank You.
Generally you can bond exposed structural steelwork steelwork as close as possible to your MET.
It is not necessary to cross bond as all the steelwork will be linked.
Reply to Help on Earthing of structrual steel?? in the Australia area at ElectriciansForums.net
Thanks for your advice bud, I actually spoke to a Gold Card holder over the weekend of whom gave me the same advice
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
