Help on furthering my PLC knowledge. | on ElectriciansForums
Discuss Help on furthering my PLC knowledge. in the Electrician Talk | All Countries area at ElectriciansForums.net
M
Mike F
Hi, I am currently an electrician working within the food manafacturing industry. I have a basic understanding of a few PLC's and various software used to view information on these.
I'm looking to further my knowledge and understanding of PLC's with the hope of moving from just simple maintance and fault finding to modifications to existing programs and also eventually writing programs.
Is there any distance learning schemes people can recommend, as i have found on scan time . co . uk but they seem a little vague.
Thanks in advance
Mike
Sorry, I've never done any PLC work. They are all manufacturer specific, so find out what makes/chips you are dealing with first so you can tailor the training. You may well find some of the manufacturers offer training as well.
We mainly use allen bradley plc and one or two S7's. I have the software for both just after some direction in this field. Many of the advertised courses, when read into seem along the lines of these 5 days domestic installer super spark scheme. I would just like to avoid these and do the proper training.
Mike
Contact Allen Bradley technical support and ask them if they offer (or know anyone that does offer) a course. Most manufacturers are keen to help folks that are using their chips.
I have emailed them already, the other main reason i put this thread up up was that i see a few of the people who post here work with PLC's (possibly Engineer54 or Tony). I just can't find the posts, can only just about remeber seeing them.
Mike
They are a programmable logic controllers. Mainly used in process machinery, they work on a basis of being able to make there own decisions, dependant on program. You can program counters, timers, relays, temp controllers etc and then display set information on to a HMI/scada. In a simple form they just compress a panel buy removing items such as mechanical counters, timers etc which over time wear and need replacement.
Hope this makes some sense of things, although it is worth remembering my knowledge isn't the best on these . Hence my wanting to look further into PLC programming and the likes.
Mike
I’ve worked mainly with Modsoft and PL7. I tried to introduce Mitsubishi Melsec for one project but got shouted down by management that didn’t know what the hell they were talking about.
I find Modsoft dead easy to work with even when using advanced maths. It’s ladder based but you can introduce blocks for all kinds of functions. Add to which it can hold full descriptions for each node. PL7 can be either ladder or literal, again I prefer ladder as it’s easy for others to follow.
HMI are the visual display units. Allow an operator to alter programmes, setting, dwell times etc.
Tony what plc's would the Modsoft software be compatable with? he programmes which i look at via RS logix/Rs linx etc are usually in ladder form and are easy to follow if you know what your are looking for.
Did you self teach or do some sort of training?
Mike
Supervisory Control and Data Acquisition = SCADA
I was originally taught on the Mitsubishi FX series PLCs but then moved to a company that used soley the SLC 500 Allen Bradley PLCs. My company sent me to the Rockwell Automation Centre in Sutton, Midlands for the full course. You cannot beat proper formal instruction.
If you want to have a go yourself then I would suggest John Ridley - Mitsubishi FX Programmable Logic Controllers (buy from Amazon). You would need the GX Developer software where you use a simulation programme so that you don't need to go to the expense of buying a PLC. The book will teach you all you need to know about the use of memory coils, timers, all manner of counters, step ladder programming and basic ladder logic then right up to using shift data registers when you've become confident enough to try.
I have the software but don't know how to get it to you. Sorry about that. Hope this helps.
Hi Mike
I've been dealing with PLCs for the last 13 years or so. I self-taught with Mitsubishi Fx then found a local night-school teaching a 3 yr course in PLC Maintenance using Allen-Bradley SLC500 so I enrolled. I moved into a job where the plant was mostly A-B plus others. So I got hands-on real-world exposure to RSL500, RSLinx and DH+. Other brands were there such as Siemens S5/S7, Omron, Keyence and Mitsi so I gained a great deal of insight into those, and got some invaluable training from Siemens too!
I'd like to recommend this series of sample lessons on A-B. Watch the lessons in order. Sample Lessons and Quizzes
Local automation companies should be able to put you in touch with courses. Some companies such as Parmley-Graham, Lockwells, LCAutomation and Routeco should find it in their interest to help!
HMIs; I have just completed a project using RedLion G3 HMIs. Fantastic. Free Crimson software on their website and good quality equipment and service.
What is your location, roughly?
Hi Mike
I'm similar to some of the guys on here. I have worked in the mining, automotive, machining and potteries and have come across an array of PLC's. Namely AB SLC500 and SL5000(I think, very old!), Siemens S5 and S7, Omrons, to small controller like keyence and festo.
You know the best training you can get, if possible go into your stores get a PLC rack, power supply, processor and input out put card or you may have a modular unit like the Mitsubishi Alpha. Power it up and practice. I did a unit on control theory when I was young and studying but from there on in when i have arrived at a company that is how I've built up confidence with PLC's. Try it if possible and if you have any other like the rest on here I will attempt to help.
PS remember the most important skills are backup and restore!
Reply to Help on furthering my PLC knowledge. in the Electrician Talk | All Countries area at ElectriciansForums.net
