Help on learning heating systems for domestic properties | on ElectriciansForums
Discuss Help on learning heating systems for domestic properties in the Domestic Electrician Forum area at ElectriciansForums.net
Wiltshire
Could someone point me in the right direction for learning everything I need to know on heating systems throughout my apprenticeship I didn’t get to do a lot of it and would like to know my stuff . Thanks
If you google Honeywell heating wiring diagrams they are self explanatory. Most systems use either two port valves for HW and CH, or a three port valve to do both. Follow the wiring and you'll see how it works. Programmer feeds heating and HW stats, stat tells required valve to open, micro switch in valve switches on boiler and pump.
Honeywell (MK) do excellent training days touring the country, quite cheap as well.
Drayton (Schneider) also do courses but more for their excellent Wiser system and hub. Maybe worth a call to see if they do a 'basics' course.
Reply to Help on learning heating systems for domestic properties in the Domestic Electrician Forum area at ElectriciansForums.net
Don't need to read again the picture tells me what I need. BTW your a bit touchy about solar, it's old hat these days 🤣 and a waste of money
Hi. Sorry if this is not allowed, but I'm on the hunt for my first electrical role. I've completed C&G level 1,2,3 currently doing my 18th...
