Help on Mitsubishi air source unit wiring | on ElectriciansForums
Discuss Help on Mitsubishi air source unit wiring in the Central Heating Systems area at ElectriciansForums.net
714gold714
Hello all
im currently first fixing for a Mitsubishi outdoor unit- puhz-sw120vha indoor unit-ehscmec
the system has an air course unit located outside, joule cylinder in loft, hydro box next to fuseboard
manifold for under floor heating downstairs which I have ran all my three core wires for my thermostats downstairs zones to this, also ran a feed and three core back to the hydrobox
Manifold for upstairs under floor heating I have ran all my three cores wires for my thermostats for upstairs zones to this, also ran a feed and three core back to hydrobox
my main question is currently I'm unsure where the zone valves will be I presume on the joule cylinder in the loft? What wires would you run to the cylinder from the hydro box? To turn on heating and hot water
thanks in advance
Hi bud,a bit more information on the system and cylinder is required. Joule make a range of cylinders,direct and indirect,and the system designer should indicate where your cabling should be.
Email the plumber at home,now...that'll teach him...:pirate:
Reply to Help on Mitsubishi air source unit wiring in the Central Heating Systems area at ElectriciansForums.net
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
I think that's the point I was trying to illustrate. If volt free contacts on a device on one supply are switching mains voltage coming from...
