H
hsuelec77
Hi all,
Completed my first pir yesterday now this client has got a three phase supply, TNS which feeds a ground floor shop and a flat above, the flat has a on peak and off peak supply. With the tails for the flat going into two kmf switches with a sub main cable of only csa of 10mm T+E for each supply protected by a bs1361 60A with a cable length of 6-8 mtrs max.
Q1 on my supply characteristics where it says main switch/circuirt breaker do i enter the details of the kmf switch ?
Q2 If the flat has the main protective bonding conductors going to the db with a earthing conductor as 4mm off the T+E this has to be upgraded? What would you code it?
Q3 Would you code old and worn pendants etc?
Q4Special locations with no IP rated luminaires?
By the way is there any courses on form filling because i haven't had much experience was mainly installing, didn't fancy doing pirs but on the flip side you can get remedial works.
kind regards
kind regards
