colshaws
Hi all, I have just finished installing a new cooker circuit and also carried out a P.I.R, do i need to supply an installation certificate or will the P.I.R cover the whole lot, many thanks.
Discuss Help on which certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
HI you will need a EIC certificate for the cooker circuit and submit to building control.The periodic will be for the rest of the property. so you need both.
Reply to Help on which certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
