help on wiring emergency switch lighting | on ElectriciansForums
Discuss help on wiring emergency switch lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
leicester
Not quite got to this stage in the project yet but trying to think forward on what needs to be done, I haven't had much experience with wiring emergency switch lighting, Live and Switch Lives. Can someone tell me if the wiring is wrong in this wiring sketch and how to rectify.
I've deliberately left out Earthing.
[ElectriciansForums.net] help on wiring emergency switch lighting
C/U PERM LIVE>>COM of key switch and to com of manual override switch/photocell etc
from L1 of key switch>> L of emg light fitting
from L1 of manual override switch or photocell etc>> L1 of light fitting
the key switch is to break the perm feed to the emergency light to mimic a lose of power.
you should feed the key switch by the same circuit as the local non/emg lighting
I knew there was something not right but really couldn't work it out. I haven't wired an emergency lighting circuit yet and something I really want to understand, thanks for the help JCE
your keyswitch should interrupt only the perm. L to the EM. it should not affect the operation of the light/s via the normal (user)switch. so you take L from supply to both switches, then L1 out of user switch to operate the light normally, and L out from the keyswitch to L on the EM.
get rid of the neon- that not needed.....
change your L out on your 2pole switch to go to L1 on emg fitting AND L on non emg
get rid of the L2 wiring on key switch
Hi guys sorry about the slow reply I'm just working it out using Daves recommendation actually drawing a switch, its certainly helped me before, and there is no spec I'm just trying to understand the wiring process of where the conductors go before/if I ever need to wire an emergency lighting circuit, I enjoy the logic side of wiring but this ones got me scratching my head
Ok got rid of the neon and ignoring the Neutral, 'L out' from the 2 pole switch now goes to 'L1' in Emergency light and 'L' in non emergency light fitting
Reply to help on wiring emergency switch lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I've been at this all night for a smart switch I've installed for exterior lighting for the house located in the eve's of the house attic...
Ah yes my apologies, thank you much appreciated.
